Old 05-07-2017, 11:58 AM   #8 (permalink)
oil pan 4
Most cars in the United States come with factory recommend tow ratings, then the hitch you install also has weight ratings (because cars don't come with towing gear). Then you use which ever is lower.
The car may have a 2,000lb tow limit, the hitch may one be rated for 1,000lb. Or the car may have a 1,000lb limit but the hitch may have a 2,000lb limit. You have to go with the lower rating.
Then you have trailer limits and tire limits of the vehicle and trailer tires.
The Following 2 Users Say Thank You to oil pan 4 For This Useful Post:
Sjoegerd (05-07-2017), Xist (05-23-2017)
