Cut the transmission temperature sensor wire , inside the cab .solder extension, could use bonded pair speker wire.
Insted of running to pin 3 to ground with resistors. Add the resistor/s from the transmission feedpin 1 to the fake signal 3rd turminal. Use a resistor sized to make the fake signal +20to60° this way you also have a functional over temperature, it just kicks in 20-60° earlier if you forget to turn it off.
Would look like this
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
Reason: Add pic
