Originally Posted by gumby79
Cut the transmission temperature sensor wire , inside the cab .solder extension, could use bonded pair speker wire.
Insted of running to pin 3 to ground with resistors. Add the resistor/s from the transmission feedpin 1 to the fake signal 3rd turminal. Use a resistor sized to make the fake signal +20to60° this way you also have a functional over temperature, it just kicks in 20-60° earlier if you forget to turn it off.
Would look like this
Now that makes sense to me and it wouldn't be hard to remove.
