the rear wheel arches could easily be sealed with stiff rubber or plastic cut to shape with tabs to secure it to the arch. in front of the wheels should be a straight or slightly curved (straight is fine, easier to make, and used by auto makers), but the distance in front of the wheel is the trick, and I'm not sure if anyone here has figured that out.
