Originally Posted by MechEngVT
In a diesel engine a constant throttle position means a constant volume of fuel is consumed per revolution. Only an engine RPM change will change your fuel used in GPH.
Not in my diesel!
My focus is fly by wire throttle. The fuelling is determined by throttle %, engine speed and vehicle speed. The fuelling is further limited by the air density limit map, which is relative to boost so smoke is reduced to reasonable levels.
There are 4 throttle position and engine speed maps, with vehicle speed interpolating between these maps.
Oh, and there's a temperature dependant map too plus lots more
So, no. There is not much correlation between throttle position and fuelling unless the conditions are exactly the same.
