Old 05-13-2017, 10:08 PM   #21 (permalink)
ChopStix
Primer is still paint!
ChopStix's Avatar
90 day: 32.46 mpg (US)
Originally Posted by JRMichler View Post
Those square sharp corners are killing your gas mileage. Get at least a four inch radius on the side and top leading edges. This would be relatively easy to do by adding a bubble to the front. Ideally, all edges would be rounded, but the front edges are most important.
If the sharp edges are bad. Then after a front bubble, could you simply take pvc pipe and slit down the length and glue that over the long side sharp edges to round them?
I realize that this might look funky. But a rounded edge made of pvc pipe glued over the sharp edge has to be better than the sharp edge alone. Am I right?
