Originally Posted by teoman
There are many options, but the simplest would be use a piece of vacuum tube as a coupling (1-2 cm) and have the servo on the side.
I see what you're saying, but that would require me to make the grill block longer than it currently is. Its not a bad idea at all. I just chose to go a different route.
