Old 05-15-2017, 03:48 PM   #32 (permalink)
JSH
AKA - Jason
JSH's Avatar
90 day: 17.3 mpg (US)
The Bolt using resistance heating instead of a heat pump is a bit of a letdown but the car has so much extra range it likely won't be much of an issue in actual use. My Spark also has resistance heat at can consume 30% of the battery during my commute. However even with "only" 82 miles of range I get by OK.
