Old 05-16-2017, 10:41 AM   #124 (permalink)
Daox
Alright, I got it all mounted and on the car last night. Unfortunately it rained and that slowed me up a bit.
Time for pics!
Traced the grill block on to the coroplast. I cut it with an exacto blade after that, and drilled holes in the coroplast.
Cut and mounted with screws. Fit great. It did require a bit of notching around the servo and its arm.
Here is the back side with servo mounted.
Soldered up the wire that will run to the arduino in the cabin. I used a 4 conductor telephone wire.
I could use a good way of making this connection water tight... Suggestions welcome!
After that it was a matter of waiting for the rain to stop and going and bolting it on. It really fit nice.
Once its painted I don't even think it'll be real noticeable at all.
The white is paper that stuck to it when I superglued it together. It will be cleaned up when I go to paint it.
View from the front of the car. Its a bit behind the license plate, but I can't really shift it any further to the right due to the wood blocks needing space.
ID:	21778   Click image for larger version
ID:	21779   Click image for larger version
ID:	21780   Click image for larger version
ID:	21781   Click image for larger version
ID:	21783   Click image for larger version
ID:	21784   Click image for larger version
ID:	21785   Click image for larger version
The Following 6 Users Say Thank You to Daox For This Useful Post:
BamZipPow (05-16-2017), Ecky (05-16-2017), IamIan (05-26-2017), NeilBlanchard (05-16-2017), samwichse (01-04-2019), t vago (05-16-2017)
