maximum vs minimum vacuum reservoir capacity...
Anyone run numbers on the payback for an oversize vacuum reservoir, perhaps even one that gets pumped down really low while plugged in, with a regulator to ensure that the booster sees normal vacuum levels? Basically the question is which is the better investment- a pound of reservoir, or a pound of battery?
Electric pumps make 21"+ of vacuum easy, though 14" is often enough for the brake booster.
Years ago I proved that for EVs, a hot water bladder delivers more heat per lb than a supplemental battery for winter heat, and am wondering if an upsized reservoir that gets pumped down while still plugged into the house could also be worthwhile...
2012 Mitsubishi i-MiEV, 112 MPGe
2000 Honda Odyssey
1987 F250 Diesel, 6.9L IDI, goes on anything greasy
1983 Grumman Kurbwatt, 170 kW "Gone Postal" twin
1983 Mazda RX-7 electric, 48 kW car show cruiser
1971 VW Karmann Ghia electric, 300 kW tire-smoker
1965 VW Karmann Ghia cabriolet, 1600cc
Have driven over 100,000 all-electric miles!
