Old 05-17-2017, 03:15 PM   #47 (permalink)
TexasElectric
As I mentioned in my last post, the rear derailer rubs against the hub motor. I did some research online looking for alternative rear derailers that would not rub (ie. a different design). I started reading about how some manufactures use road bike rear derailers on mountain bikes. So just for kix i removed my cyclocross bike's rear derailer (Shimano 105 5800) and mounted it on the mountain bike (see picture below). I am able to 'walk' the derailer through all the gears by hand. I haven't secured the shifting cable yet. I am pretty sure it will work no problem, If that's the case I'll buy one in the next day or two.
I'm starting to assemble the cells, (See pictures below). I am going to assemble 5 cells in parallel, then heat shrink them together. I will do this for all 16 of the 5p cells. Each 5p 'pack' will have 3 wires coming out of it, (positive, negative, and a voltage regulator wire going to the BMS). Lastly I will connect all of the 5p 'packs' together is series to give me 48v, 27.5ah.
Tomorrow I will spot weld the nickel tabs to the cells.
I am still able to lift the bike off the ground, but I am still missing the hub motor, (it's not mounted on the bike yet).
I also want to point out that the wheel I received (700c) from eBikeling is in fact a 700c wheel. What I noticed today (that I didn't notice yesterday) is that the inside of the rim is a little deeper than my other rims, therefore when i put a tire on it the tire bead falls down about an inch into the inside section of the rim (where the inner tube sits). I have to be careful to make sure the tire is center on the rim all the way around before pumping it up to pressure.
The Following User Says Thank You to TexasElectric For This Useful Post:
vskid3 (05-17-2017)
