Originally Posted by nemo
So if the gauge is 60 PSI then the 2% is 1.2 PSI from 18 to 36 PSI (30 to 60 percent of scale). Would have thought the the percentage would have been of the actual reading not of the gauge limit.
If it were, then if you were reading 1psig your error would be 0.02psig. Not realistic.
