Originally Posted by oldtamiyaphile
for the average car that holds closed loop as best as it can weight reduction beyond the easy won't be worth the effort.
^^ This ^^
Weight reduction is fine and dandy to a point. Changing rims, sure, taking out the back seats, why not... But when you start to go as far as swapping your flywheel (If your changing the clutch anyway go or it), remove your dash to tear out the sound dampening on your firewall or taking out airbags, it simply isn't worth the effort (or safety risks in some cases).
