Old 05-24-2017, 12:24 AM   #180 (permalink)
freebeard
Do you see the round thing inside the rear quarter, just below the window in the door alongside? That is the stop for the seat back. There is a luggage well between the rear wheels.
I went out and measured:
  • 42" from B-pillar to B-pillar
  • 9" from B-pillar to driver seat-back
  • 25" from B-pillar to rear seat back
  • 4" from seat frame to luggage floor
  • 36" between wheelwells
  • 16" deep luggage well
With Type III engine cooling, one could cut out that firewall. Even use a Type III rear deck and engine hatch. The BGW van is the most aerodynamic. It adds a 3ft triangle of space. If space is a problem, cut the Beetle body long (and cut slits in the fiberglass's edge to re-contour that) and have a longer body for incrementally more work.
Most importantly you'd have opportunity to steal this air vent detail from the Citroen Tubik concept:
