Originally Posted by MPaulHolmes
The default settings for the new code is a nissan leaf permanent magnet motor. Are you using an induction motor?
Yes it is an induction motor with an older board. I have downloaded firmware that is dated Oct 26, 2016. It looks like the latest and runs the motor.
I am still trying to configure the regen for the motor. It works when the motor is running at a certain rpm but then starts to drive the motor. Can you point me in the right direction as to what values to change to make this work better.
Thanks.
