Old 05-29-2017, 12:32 AM   #201 (permalink)
cRiPpLe_rOoStEr
Probably the main thing would be the 'portal' axle with reduction hub. I think it is a distinct part from the reduction boxes in the Type II bus.
I'm not sure about it, but it would sound smarter to re-use those very same reduction boxes in the Kombi instead of developing newer components. Germans take this cost-cutting measure so seriously to the point that a W124 Mercedes-Benz relies on the same steering tie-rod ends used in many older air-cooled Volkswagens with the torsion beam front suspension
I'm wondering if the wheels are worth more than the rest of the car.
It doesn't sound so likely to happen in Brazil, since even an older car like that one would still retain a considerable value compared to a similar in Europe or the U.S.A. that would've been most likely to go for scrap.
