Old 05-29-2017, 10:08 PM   #4 (permalink)
oil pan 4
Don't worry about hurting a tire.
When they are bulk shipped from factory they are packed into a tractor trailer then repeatedly rammed with a warehouse tug until no more tires will fit.
I have used a 10,000lb flight line tug to run over the edge of a tire on a split rim to break the bead. Reused the tire, it needed a new tube and wouldn't come off the rim using conventional means.
MetroMPG (05-29-2017)
