Old 05-30-2017, 02:01 PM   #67 (permalink)
aardvarcus
aardvarcus's Avatar
Deep Blue - '94 GMC Suburban K2500 SLE
90 day: 23.75 mpg (US)
Griffin (T4R) - '99 Toyota 4Runner SR5
90 day: 25.43 mpg (US)
Progress has been slow due to other things taking precedence, managed to get more interior firewall insulation done, clutch master cylinder mounted, and the transfer case shifter. I had some issues with the lower radiator hose, bought a gates stock replacement piece, but it didn’t fit right and rubbed the frame and brake lines. Had to disassemble the piece (where there is a tee fitting in the center) and trim bits off of all four of the ends to get it to fit right without rubbing. That took forever as I had to install it and remove it multiple times until I was satisfied. Got the coolant overflow/reservoir tank mounted and the lines connected to it.
I started inspecting and test fitting the electric fans, as I mentioned in another thread, putting two 18” Thunderbird fans in a 34” radiator means they will overlap a bit on the sides and somewhat complicate mounting, but I don’t want to take any chances with cooling.
The Following User Says Thank You to aardvarcus For This Useful Post:
deejaaa (05-31-2017)
