I want to do a radiator and oil flush.
For the oil, i want to run it with ATF for 15 minutes. Then fill with 0-40 mobil 1.
For the coolant, i want to do a flush with a bit of vinegar, the with a bit of soap followed by distilled water and finally the coolant.
Do you guys recommend anything else? Or will I corrode the aluminium block with the vinegar?
