Old 06-06-2017, 07:08 AM   #80 (permalink)
sidecar
That sounds quite challenging, but anyway, since the seating arrangement would be quite similar to a motorcycle, eventually you should not disconsider a tricycle.
there is also staggered tandem, which makes a shorter if slightly wider cockpit, but enables a rather better view forward with more elbow room for both driver and passenger.
