Originally Posted by cRiPpLe_rOoStEr
I don't see why a hybrid car engine would require any "special" plating at all.
There is a crank, rod coating used on race engines that supposed to increase power, reduce heat/friction and increase fuel milage. The company claims the coating process is applied here in the US.
There are coatings out there like this, but as far as I know it's not unusually toxic, they are done in the US and pretty much only to race engines, not applied stuff that goes down a production line for daily drivers.
Then to play devils advocate, if this coating is so good why only apply it to hybrid engines.
If none of us have heard of it then it probably does not exist.
