slowmover — I thought I'd let you answer the question about bushings, but rather than let it fall between the cracks...
Just as there is an optimal line to follow through a curve, just touching the apex, there is an optimal line for a straight line; and it's ...a straight line.
Constant course corrections work the tires and affect wear and fuel economy.
Close enough?
deejaaa —
Once the various body and suspension bushings age, they allow steering slop. It's serious enough to be a measured concern: course corrections per 100-miles.
With trucks it takes less of a problem to create more inefficiency.
Agreed.
