Yeah, I moved long before the waters rose. Sounds like nothing was spared in the Midwest that year. I'm on higher ground now so I just have different things to be concerned with.
Thanks for the how-to. I finished it yesterday and it works like a charm. I now wished I'd either used a lighted switch or mounted it on the shift knob as you did. I assume you just took a drill press to the knob for routing the leads down and out through the boot.
That may be next weeks proj.
