Originally Posted by Stubby79
I'll point out what became readily apparent when I (belatedly) did my homework on motorcycle power requirements...it takes just as much power to move a motorcycle - with is small frontal area but bad aerodynamics - as it does a car at highway speeds. The motorcycle only shines on hills and acceleration, due to the lack of weight. You'll need basically as big of a battery pack as you would for a car...if you are doing highway speeds.
Thanks for the info.
As for your Elantra...LRR tires, warm air intake, and whatever aero mods you'd be comfortable with will get you those few extra MPGs.
I don't mind trying stuff as long as it's not expensive, and it doesn't look goofy on the car. Hidden stuff would be even better.
