Originally Posted by ar5boosted
I put it on a Suzuki but then I had some tuning issues - best described as a fail on my part. I never was able to duplicate the economy improvements on the EFI engine due to lowered engine temperatures. I injected too much cold water and blew the Head-Gasket. My enthusiasm declined after that although I do have reflections on how I could have done better.
The colder air stream and the higher concentration of oxygen might have fooled the ECU to enrich the mixture instead of leaning it. Maybe if you got it injected after the MAP and temperature sensors, it could have increased the fuel economy in a similar level to what you hve experienced with the carburettor-fed Mitsubishi van.
