Old 06-11-2017, 11:38 AM   #91 (permalink)
ar5boosted
ar5boosted's Avatar
So, I have been looking lately at one new Suzuki, it's a resurrected old model.
- Suzuki Baleno MPG - Actual MPG from 13 Suzuki Baleno owners
I had the old model which got 25-30mpg. The new model has ie 2016/2017 now gets 44mpg.
The engine size went down from 1.6 to 1.0T but I know for a fact that these new cars are not driven softly. What are Suzuki doing ?
This new turbo baleno and vitara are now very close to being as economical as the 2003-2015 models of Prius Toyota Prius MPG - Actual MPG from 5,977 Toyota Prius owners . In fact you could read them as being the same.
My half-baked idea is that although turbo-engines not stressed running at a vacuum, it's not the air-pressure that's causing the vacuum but the fuel. If you stop providing the fuel the engine stops.
So would it be-possible / has-it-been-tried to run a convential ICE with inlet-manifold boost and a very small amount of fuel, say only just enough to keep the cylinders firing? Then simply really slow down the fueling and manage temperatures.
This would equal a high-efficiency high-compression engine right ? Obviously this requires computers that do custom thermal management and not thinking like "oh just richen everything up to cool the cylinders".
If not this, then what are Suzuki doing ? :-)
2003 Renault Scenic - 30% more power with no loss in fuel economy.
1991 Toyota GT4 - more economical before ST215W engine-swap.
previous: Water-Injected Mitsubishi ~33% improved.
future - probably a Prius
