Old 06-12-2017, 05:15 PM   #101 (permalink)
RustyLugNut
If you want economy, you want to recycle your lost heat.
Originally Posted by Enki View Post
Heat will build up, however. That's the reason I swapped the intercooler back in once ambient temps climbed past 90 on the regular; not a big fan of seeing 180 degrees at the manifold during city driving.
High intake temperatures and high turbulence result in increased fuel reactivity and thus more rapid flame fronts. We all know this to be true. So, couple this condition with a ultra lean homogeneous fuel mix which is a lazy combustion mix by nature, and you can extract useful torque to putter around with.
