Old 06-12-2017, 08:22 PM   #116 (permalink)
ar5boosted
ar5boosted's Avatar
Originally Posted by teoman View Post
Water injection reduces NOX. I am not sure if it is just the reduction in temperature or some chemical reaction, but I wonder if injecting it in to the exhaust would have any use whatsoever.
I've heard that too.
My understanding of how it does this is simply by reducing the temperature of the combustion chamber. I don't think it would do anything but make steam come from the exhaust :-) Somebody could report you for having a smoky car :-(
As I understand them lean-burn engines is that they are mechanically-reinforced engines designed to operate at higher temperatures and pressures than 'normal' engines. The unfortunate chemical result of this is higher NOX levels which makes nitric-acid that kills forests.
Filling up with water is a bother. I was running 50% water and 50% fuel which meant carrying around 20L of water and filling that twice as much as I was filling the fuel. General consumers wouldn't go for that.
2003 Renault Scenic - 30% more power with no loss in fuel economy.
1991 Toyota GT4 - more economical before ST215W engine-swap.
previous: Water-Injected Mitsubishi ~33% improved.
future - probably a Prius
