Old 06-12-2017, 10:27 PM   #172 (permalink)
Vman455
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
It's been a while, but I finally got a chance to do some work on the Prius. As of today, it has side skirts once again, this time in coroplast to prevent the wrinkling I had before:
And, you can see that bar over the rear wheel where I'll be attaching the wheel skirts.
I used a door sweep, pictured in an earlier post, bent by hand to a nice curve to clear the tire. It's bolted in the front to the plastic rocker, and in back has a notch that slides over a spaced bolt in the bumper cover:
This allows me to flip the bar, and eventually the whole skirt, up and out of the way with no tools:
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following 8 Users Say Thank You to Vman455 For This Useful Post:
BamZipPow (06-13-2017), COcyclist (08-22-2017), Daox (06-13-2017), Ecky (06-13-2017), elhigh (06-17-2017), Joggernot (06-13-2017), MetroMPG (06-16-2017), ThatDudeOrion (06-13-2017)
