Old 06-15-2017, 07:36 AM   #68 (permalink)
aardvarcus
aardvarcus's Avatar
Deep Blue - '94 GMC Suburban K2500 SLE
90 day: 23.75 mpg (US)
Griffin (T4R) - '99 Toyota 4Runner SR5
90 day: 25.43 mpg (US)
Progress has been slow, mainly due to other priorities plus getting myself wrapped around the axle a few times on some details (such as the oil cooler lines) but now I believe I have that resolved.
I have gotten some pretty significant strides made towards the electric fan setup, I ended up deciding to lap my two 18” fans in the middle to get them to fit within the 34” radiator. In order to do that without making the assembly too thick, I cut away at the excess shrouding at the overlap point, leaving myself roughly a half inch of clearance between the fan blades and any other items.
I got the first round of heat welding (melting them together with old soldering iron) the shrouds completed, so the fans are securely attached together. I will have to do a few more minor modifications to get the shrouds to work together well with the core support at the bottom of the radiator as well as any modification to attach them to the shroud at the top.
Anyway, some pictures.
ID:	21976   Click image for larger version
ID:	21977   Click image for larger version
ID:	21978   Click image for larger version
ID:	21979   Click image for larger version
ID:	21981   Click image for larger version
