Old 06-17-2017, 02:25 PM   #2 (permalink)
Stubby79
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
Check for power at the connector terminals to confirm, while it's running if possible. Then deduce if it's one wire or the other that's not getting continuity. You can test for continuity between said terminals and ground and between them and +12v. I'd assume they run on a ground-pulse like everything else out there does, so you should have continuous +12v on one terminal, and nothing or pulsing ground on the other. If you are not getting both, you then can tell which one you are trying to trace/fix.
