Originally Posted by Daox
I completely agree that welding to the aluminum transmission case is a bad idea. That is why I will be using glue. I'm not sure what type of glue yet, but cars these days are mostly glued together. I'm sure I can find something that will hold up to the ~15 psi that most cooling systems are designed for.
fwiw, you can use silver-solder to join Aluminium successfully. I actually just gave a course in Japan on using Durafix which is a type of Aluminium Solder for want of a better description.
[My Aluminium Rearmount-turbo-intercooler pipe]
You can find durafix on ebay or somewhere. I made some Aluminium computer-cases
https://forum.makehackvoid.com/t/diy...-projects/1171 just to show that it can be done.
It requires inexpensive tools like a propane burner to heat the base metal.
See this link to youtube for other examples :
https://www.youtube.com/results?search_query=durafix
2003 Renault Scenic - 30% more power with no loss in fuel economy.
1991 Toyota GT4 - more economical before ST215W engine-swap.
previous: Water-Injected Mitsubishi ~33% improved.
future - probably a Prius
