@ Jurgis without the wiring diagram no one can say. but u better go for the injection relay than the ignition. otherwise the fuel is still dripping...
Originally Posted by MetroMPG
I have a question too: how does the clutch+throttle switch control how long the starter is engaged?
the alternator pin went from 0v to 12v when the engine is running. so we have 12v at both ends of the relais coil. thats a 0v difference, so the relais is released and the starter stops. this is faster than the drivers hand can be.
jic: when the alternator fails and the starter will not stop, u have to open the service switch.
