You could get a light duty truck rear axle, a 3rd member, have it shortened by a machine shop.
The total cost would depend a lot on if the axles could be shortened down as far as needed. Some axles have a shank that is thinner than the splines. Most are the same diameter as the splines.
Total coat of machine work should be well under $1,000.
Also last year I bought a 21kw peak, 17.5kw run generator for $1100. Normal retail is around $3,600.
