Old 07-02-2017, 07:32 AM   #14 (permalink)
PASY
Hey Seifrob!
The good thing about the plugin is, it records everything for you. So afterward it's easier to analyse what you did. It gives you a map of where you've been with indication (color) about places where you used more fuel. Plus, it place everything in order so you can keep track of your deplacement by date...
I don't thrust the MPG indicator of Torque, I think it's a little optimistic... Not sure it's accurate. The other infos seems alright.
I may build a consumption indicator with a raspberry pi....
