Old 07-03-2017, 03:17 AM   #16 (permalink)
seifrob
Permanent Lurker
seifrob's Avatar
Dáčenka - '10 Dacia / Renault Logan MCV 1.5 dCi (X90 k9k)
90 day: 47.08 mpg (US)
Hallo back! Now I am little confused as what you described Torque does for me without any additional plugins (I have just standards - realtime, map view, code check, adaptor status etc that cane with the app. Then I made my dash and then set logging in Settings, DataLogging and Upload menu. Back home I use either map view, or export to Google Earth. In the evening I will try to write more, from my desktop PC.
MPG info can be calibrated. Take full tank, reset torque trip, drive with torque on. The further the better. Refill at the same pump, calculate your MPG, and compare to the average MPG reported by Torque. Then divide these two numbers, you should get number around 1. Enter this as MPG trim adjustment in Vehicle profile. Again, more hopefully in the evening.
The Following User Says Thank You to seifrob For This Useful Post:
Hypochondriac (07-03-2017)
