Old 07-03-2017, 09:56 PM   #17 (permalink)
Hypochondriac
Honda - '00 Honda Accord
90 day: 22.95 mpg (US)
Originally Posted by seifrob View Post
Hallo back! Now I am little confused as what you described Torque does for me without any additional plugins (I have just standards - realtime, map view, code check, adaptor status etc that cane with the app. Then I made my dash and then set logging in Settings, DataLogging and Upload menu. Back home I use either map view, or export to Google Earth. In the evening I will try to write more, from my desktop PC.
MPG info can be calibrated. Take full tank, reset torque trip, drive with torque on. The further the better. Refill at the same pump, calculate your MPG, and compare to the average MPG reported by Torque. Then divide these two numbers, you should get number around 1. Enter this as MPG trim adjustment in Vehicle profile. Again, more hopefully in the evening.
I was driving and the app was showing 26 mpg average. Then the app crashed, when it reloaded it was now showing 18 mpg average. I wanted to know if there was a way to get the original number back
