Originally Posted by Xist
When I took it to a mechanic he said one front wheel was slightly larger than the other, but he said they were the right size.
I'm more than a little confused here. How can one wheel be "slightly larger" than the other? Wheels only come in fixed sizes. It's not likely that 14 and 15 inch wheels would even have the same bolt pattern.
Maybe you/he meant that the tires were slightly different sizes? If so, so what? Unless they're on drive wheels with a limited slip differential, it's not going to hurt anything.
He didn't mention they were cheap tires and after the tread came off and damaged my car I realized two tires, including the one that blew, were one size too small.
Having tires one size too small (or two large) does nothing except perhaps affect your fuel economy and speedometer accuracy a bit. Nor is it going to cause tread separation.
