Old 07-09-2017, 02:53 PM   #224 (permalink)
rmay635703
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Originally Posted by roflwaffle View Post
As long as you aren't driving too fast (> 50mph?), I'm hoping you'll get 30-40 mpg. Maybe less if the rear end is causing a lot of drag, but an extra few hundred pounds won't hurt Prius mpg much unless you're doing a lot of stop and go.
Not sure about 40mpg
But I would think 30mpg at city speeds might be possible.
For Higher speeds he would need to start constructing a long belly pan and likely be careful with tire /rim selection and start streamlining gaps and protuberances
Alignment and stance of the chassis will likely need touching as well, he would need to set things a little on the squirmy side to get best efficiency.
Step 1 is to drive the chassis with instrumentation a lot to figure out where he is starting.
A CD .75 brick is likely lower on the spectrum than some might figure but also easier to streamline.
