Underdrive pulley helps a little bit, but it's more effective as a cheap way to add a few horsepower at high revs. If you want to mess with your power steering, electric power steering or reducing the bypass valve pressure will get better results. Water pump and alternator don't really show significant gains until higher speed, maybe a lightbulb or two worth of power.
