Old 07-11-2017, 07:04 PM   #7165 (permalink)
badfishracing
Is the hardware overcurrent, set by VR1, an actual TRIP/Shutdown, or does it simply cut back the PWM signal?
I'm having an issue with a modified, overpowered, PS board. When I hit full amps, 511 as seen on the RTD explorer, it seems to cut way back on power, even through the PWM still says full voltage?
I was running about 1250 amps (seen as 511) at only 50% PWM, for about one second, then power fell off, PWM showed 100%, but it felt like about 25% power.
