Old 07-17-2017, 06:22 AM   #277 (permalink)
ar5boosted
ar5boosted's Avatar
Originally Posted by toc View Post
Simple approach is to add an injector into the intake after the airflow meter and calculate a pulse width based on current fuel injection pulse width (be it 0.2 times or less)?
Tune the injection time based on real world findings..
Is that a dumb idea?
Sounds ok to me. I've been told by the background neighsayers that the injectors will rust. However, Injectors are cheap and plentiful at the wreckers and I bought one for $3 to test how long it would last but got distracted.
Using spray-nozzles is problematic for various reasons. 'Limiting' is a better description, however that's what I used and could get it to work in a somewhat approximate system.
I based water input at a constant rpm of about 1,100 rpm on my Mitsubishi. Slightly above idle and slightly below accelerating values, but I was satisfied with that.
2003 Renault Scenic - 30% more power with no loss in fuel economy.
1991 Toyota GT4 - more economical before ST215W engine-swap.
previous: Water-Injected Mitsubishi ~33% improved.
future - probably a Prius
