Old 07-17-2017, 09:06 PM   #52 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Originally Posted by jray3 View Post
I didn't realize until recently that my 2000 Honda Odyssey actually has a tiny radiator in the air filter box that only gets coolant flow in very cold conditions.
I also did not know about this feature, and would also like very much to know if any other models had this feature installed from the factory.
I'd rather not just "go hotter 'till she pings".
I don't worry so much about that. Even if the intake air is heated to near the boiling point of water, the fuel spray from the injectors should cool the air to a few degrees above ambient. This happens because the fuel cools off the intake air as it vaporizes and sucks in latent heat of vaporization from the heated air. I already heat the air in my Magnum to about 40 or 50 F above ambient with a old Ford Probe heater core.
The Following User Says Thank You to t vago For This Useful Post:
jray3 (08-01-2017)
