Old 07-19-2017, 12:08 AM   #5 (permalink)
redpoint5
90 day: 29.78 mpg (US)
Peltiers require a temperature differential to generate electricity. This means one side has to absorb the waste engine heat, and the other side has to remove the heat through a heatsink or water cooling (which is then cooled by a heatsink).
I wonder how much surface area you would need, and how much weight it would add, not to mention the cost.
