Old 07-19-2017, 05:35 AM   #22 (permalink)
smallscaleH2
Originally Posted by jamesqf View Post
If you're electrolizing with DC, then H2 and O2 should come off different electrodes, making separation fairly simple.
The hho people use interlocking plates like a lead acid battery to get a lot of opposing plate surface are really close to each other. The H and the O come out pretty much on top of each other.
Yes, I read that the H2 will collect at the cathode (-), and oxygen will collect at the anode (+), so it's the anode (+) side where the oxygen needs to be discarded from.
Ok. So I'd need to make sure that the plates are air-tight sealed. I think that's not normally the case (the cells in the smaller electrolysers -the Ice blocks- might be air-tight sealed, but these contain many plates). The biggest electrolysers (101 plate electrolysers) have 101 plates (in a single "cell" ?) So it's probably not possible to seperate these off ?
Can someone look into this ? The 101 plate electrolysers have pdf's with schematics over at the pwm3g page.
Either one will do I guess; if I were to use ice blocks, I'll just need a lot more of them; the ice blocks can make 1 liter of gas per minute @12 amps, but I seem to understand it can make up to 5 lpm when boosting it to 25 amps ? Anyway, at 1 lpm, I'd thus need 10 to 15 ice blocks to replace a 101 plate electrolyser (that would increase cost a lot -840$ x 15 = 12600$ compared to 3000$ for the 101 plate electrolyser-), if it can make 5 lpm, cost would be 4200$. The latter's still seems reasonable.
I'd need to attain 3 lpm to match the Bauercomp compressor, 0,4 lpm to match the BRCfuelmaker, 1,4 lpm to match the Coltri MCH5, and 3,6 - 15,5 lpm to match the CORKEN.
So we'll need just 1 electrolyser, but several compressors.
