Old 07-20-2017, 01:27 AM   #20 (permalink)
teoman
teoman's Avatar
A3 - '12 Audi A3
Originally Posted by California98Civic View Post
I saw a module on digikey.com that offered 14.5 volts and 6 amps. I bought a few lower power ones for experimenting with my daughter a few years ago. Those were just toys, for toy projects. It seems possible that you could build a system around the exhaust pipes or muffler more easily because less oil/grease and it is open to the wind for cooling one side. I wondered about using my aero diffuser under my rear bumper as a platform for tiles near the muffler. There is a lot of heat back there, but not the supper heat of the exhaust header and CAT. I thought of it after reading that BMW was experimenting with electricity generation using the muffler end of the exhaust system.
That is not the power generation capacity of the unit.
They are also pretty good coolers. Verry inefficient but very compact. For evey 5 Joules of energy you put in to it, it sucks 1 joule of energy from one side to the other side. So you have 1J of thermal energy sucked from one side and 6j of thermal energy pushed out the other side.
