It is Important to note that I will either be installing the Catalytic converters from a 1st gen insight (made to handel higher NOX output) or be doing water injection in conjunction with a NOX sensor from a ford diesel to try and keep emissions in check.
I have both setting around. The cats came off my insight and only have ~5,000 Miles on them.
The NOX sensor will have to be monitored via a Arduino. I need the voltage range outputs, and I cant find the info I need for it....
A word of caution, go too crazy, and It may throw a code with the rear O2 sensor. Easily solved by disabling it in the programming of the ECU later on.
Reason: more info
