Old 07-26-2017, 09:26 AM   #8 (permalink)
teoman
teoman's Avatar
A3 - '12 Audi A3
It is a signal wire so i doubt you would need such a high capacity relay (unless you want to open and close the output of the alternator).
There was a circuit design in a recentish thread that let you change the signal wire and have the alternator off or charge at a higher voltage. You could use such schemes to have the alternator charging wile you apply brakes.
