It's off-topic, but since you like that, here a motorhome that uses the same geometry:
If you find the four-way intersections at the nose top and side you can see the underlying octahedron. Each hexagon requires one narrow pie-cut. If it's metal: butt-weld, then on to the English wheel.
Also, since you mention Bucky Fuller (and crosswind gusts), here's an early version of his Omnidirectional Transport:
