Old 07-26-2017, 05:16 PM   #10 (permalink)
oil pan 4
Unless you run a Honda insite engine tune on the insite converter, it seems useless for reducing NOx.
The converter gets loaded up with NOx and the ecu runs the engine rich every so often to regen the anti-NOx catalyst.
With out that regen the converter loads up with NOx and then the NOx blows straight through.
I would just use a normal converter.
http://ecomodder.com/forum/showthrea...urn-35095.html
